[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Arif Arham
arhamilis at gmail.com
Thu Nov 10 20:41:09 PST 2011
Sorry, Noli, I only have dual-boot, XP and ubuntu 11.10 ^_^
Have you uninstall/purge and reinstall Qgis? Also, delete qgis directory
(eg. /home/user/.qgis ).
Reinstall Qgis and the plugin.
-Arif
___________________________
KhazanahArham.wordpress.com <http://khazanaharham.wordpress.com>
On Thu, Nov 10, 2011 at 5:47 PM, Noli Sicad <nsicad at gmail.com> wrote:
> Arif,
> Have you make it working in Mac OS X?
> Yes, I created first a vector layer. It means also that it opens a
> vector layer before I do the digitizing.
> From, Menu, Layer -> New -> New Shapelayer (Polygon) before digitizing.
> It is working in Ubuntu 10.04, not in Mac OS X.
> Noli
> On 11/10/11, Arif Arham <arhamilis at gmail.com> wrote:
> > Try open a vector layer, first.
> > On Wednesday, November 9, 2011, Noli Sicad <nsicad at gmail.com> wrote:
> >> Yes, I restarted QGIS in Mac OS X when I active and deactivate it.
> >> It is not working in Mac OS X.
> >> However, I just boot up Ubuntu. It works in Ubuntu. I was able to draw
> >> rectangle, oval and circle geometry now.
> >> Thanks.
> >> Noli
> >> On 11/9/11, Saber Razmjooei <razmjooeis at faunalia.co.uk> wrote:
> >>> I think you only need Rectangles oval digitizing plugin (0.1.2)
> >>> If you activate/deactivate it from plugin manager, I noticed I had to
> >>> restart QGIS.
> >>> Cheers
> >>> Saber
> >>> On Wed, 2011-11-09 at 21:59 +1100, Noli Sicad wrote:
> >>>> OK. The inactive green rectangle is showing up again.
> >>>> Installing the 0.1.2 Rectangle ovals digitizin plugin.
> >>>> I also install the 0.1.6 Rectangle, Ovals, Diamonds.
> >>>> What is the difference between these 2 plugins?
> >>>> I installed one by one. It did not work. I installed both of the them,
> >>>> it also did not work.
> >>>> However, it is totally not working in Mac OS X.
> >>>> Noli
> >>>> On 11/9/11, Noli Sicad <nsicad at gmail.com> wrote:
> >>>> > It was inactive. Nothing happened if you drag the rectangle.
> >>>> > Now, I uninstalled and installed it again.
> >>>> > Now, the icon inactive is gone.
> >>>> > It is totally not working in Mac OS X QGIS 1.7.1.
> >>>> > I will checked Ubuntu in few minutes. After I download Qt 4.7.4. It
> is
> >>>> > quite big download 1.3G for Mac OS X.
> http://labs.qt.nokia.com/2011/11/08/qt-4-7-4-release-bundle-for-symbian-news/
> >>>> > Thanks.
> >>>> >> Select a shape from the toolbar, in the canvas: click and drag.
> >>>> >> Cheers
> >>>> >> Saber
> >>>> >> On Wed, 2011-11-09 at 21:26 +1100, Noli Sicad wrote:
> >>>> >>> OK. I saw it. Thanks.
> >>>> >>> I am now in Mac OS X.
> >>>> >>> My laptop is triple boot :-).
> >>>> >>> I toggled the Pencil icon - edit, yet I could not make to change
> or
> >>>> >>> use the defaullt rectangle to draw.
> >>>> >>> How do you use this plugin?
> >>>> >>> Noli
> >>>> >>> > Works for me under Ubuntu 10.04.
> >>>> >>> > The icon should be towards the end of your Digitizing toolbar.
> You
> >>>> >>> > need
> >>>> >>> > to click on it and hold to see other shapes.
> >>>> >>> > Cheers
> >>>> >>> > Saber
> >>>> >>> > On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
> >>>> >>> >> This plugin seems not to work with Ubuntu 10.04.
> >>>> >>> >> Yes, I checked in QGIS manage plugin. It installed by I could
> see
> >>>> >>> >> the
> >>>> >>> >> icon and the menu entry in QGIS.
> >>>> >>> >> I created a new shapefile and I toogle to edit. No icons
> showing
> > in
> >>>> >>> >> the toolbar that resembled or look like this.
> http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
> >>>> >>> >> Any instruction how to make it work in Ubuntu?
> >>>> >>> >> Thanks.
> >>>> >>> >> Noli
> > -Arif
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111111/91793694/attachment.html>
