[Qgis-user] graduated symbols for point layers
    Caroline Rendon
    caroline.t.rendon at gmail.com
    Mon Nov 14 08:06:42 PST 2011
Hi Sake,
This doesn't work for me. The symbols still appear in graduated colors, all
the same size - and the size doesn't seem to change when I change the
number, although it does between millimeters and map units. I'm sure
there's just something I'm missing (I'm new to QGIS) but I can't figure it
out. Thanks for your help!
Caroline
On Sat, Nov 12, 2011 at 3:08 AM, Sake Wagenaar <sw1234 at planet.nl> wrote:
> Hi Caroline,
> If you use new symbology, the option to scale point symbols is hidden
> under the button 'Advanced'. With 'Size scale field' you can select a
> field. Next you have to change 'Size', to give the symbols the size you
> want. If the values are large, and you use millimeters, the symbols get
> much too large, even if you use the smallest possible value for Size
> (0,01).  A better option is to use map units.
> Sake Wagenaar
> Op 11-11-2011 23:08, Caroline Rendon schreef:
>  Hi,
> I'm trying to create graduated symbols for a point layer, and the only
> option it will give me is by color, but I want graduated symbols by size. I
> was only able to get the color to work with "old symbology" because in new
> symbology the layer would just disappear altogether and I had to re-add it.
> So in old symbology I can get dots of different colors but not different
> sizes. Am I missing a plugin or something? I'm working in 1.7.1 on Win XP.
> Thanks in advance for your help!!
> Caroline Rendon
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111114/193638c2/attachment.html>
