[Qgis-user] Trouble digitizing polygons
Giovanni Manghi
giovanni.manghi at gmail.com
Thu Nov 17 12:54:58 PST 2011
> I get an error: "No se pudo añadir el objeto espacial
> porque eliminar las intersecciones de polígonos cambiaría el tipo de
> geometría" (The feature could not be added because removing the polygon
> intersections would change the geometry type).
have you enabled topological editing/avoid intersection of new
polygons/snapping also in another layer with polygons in the same spot
where you are digitizing?
cheers
-- Giovanni --
