[Qgis-user] Trouble digitizing polygons - SOLVED
Carlos Cerdán
sig.upagu at gmail.com
Thu Nov 17 13:29:04 PST 2011
El 17/11/11 15:54, Giovanni Manghi escribió:
>> I get an error: "No se pudo añadir el objeto espacial
>> porque eliminar las intersecciones de polígonos cambiaría el tipo de
>> geometría" (The feature could not be added because removing the polygon
>> intersections would change the geometry type).
> have you enabled topological editing/avoid intersection of new
> polygons/snapping also in another layer with polygons in the same spot
> where you are digitizing?
> cheers
> -- Giovanni --
Hi Giovanni:
Yes, It is!!! I've enabled topological editing in three more polygon
layers. Now I've enabled the layer I'm working only and it fixed.
Thank you very much
Carlos
