[Qgis-user] Problem importing raster file
Justin Correia
jcorreia at uoguelph.ca
Tue Nov 22 07:10:40 PST 2011
Hi, I've been stuck on a problem for a few days now and could really use some help. I'm having the same problem reported in a previous post (Included below). Does anybody have suggestions to why this error (unable to read range file) may be occuring and how it can be fixed?
Thanks,
Jay
Subject: Re: [Qgis-user] Problem with QGIS importing raster
into GRASS - msg#00134
List: qgis-user-gis
Mail Archive Navigation:
by Date: Prev Date Index by Thread: Prev Next Thread Index
I just tested to import your raster and I had no problems whatsoever
when adding it to the QGIS canvas.
Cheers
-- Giovanni --
On Wed, 2011-10-12 at 04:08 -0700, Hannah Pethen wrote:
> Hi
> The raster is attached.
> I should clarify that the data is in a 'local' grid, and so cannot be
> tied to a known co-ordinate system. The co-ordinate system chosen for
> the GRASS mapset (British National Grid) is for expediency. As the
> co-ordinates of the local grid are still within the numerical
> parameters of the British National Grid co-ordinate system (i.e. it
> still appears within the red 'location ' box), I cannot see that this
> should cause it to fail when projecting but if it has, any thoughts on
> how to correct it would be appreciated.
> Thanks
> Hannah
> From: Giovanni Manghi <giovanni.manghi at xxxxxxxxx>
> To: Hannah Pethen <hannahpethen at xxxxxxxxx>
> Cc: "qgis-user at xxxxxxxxxxxxxxx" <qgis-user at xxxxxxxxxxxxxxx>
> Sent: Monday, October 10, 2011 10:17 PM
> Subject: Re: [Qgis-user] Problem with QGIS importing raster into GRASS
> Hi,
> I just tested in my Windows Seven 64 bit VM with qgis-dev/osgeo4w and
> I
> cannot replicate it.
> Can you share one of the rasters which is causing the crash?
> Cheers
> -- Giovanni --
> On Mon, 2011-10-10 at 13:45 -0700, Hannah Pethen wrote:
> > Dear All
> > I am experiencing problems importing rasters from QGIS into GRASS
> > using the GRASS toolbox in QGIS. Having created a new location and
> > mapset, I attempt to import my raster into GRASS using the toolbox
> in
> > QGIS. When I run the r.in.gdal command, the raster is sucessfully
> > created but when I click on 'View Output' I get the following error
> > message:
> > Cannot get map info
> > Cannot run module
> > command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.g.info
> > info=info rast=TIN280911 at GurobDEM<br>TYPE:-1
> > <br>
> > GRASS_INFO_WARNING(6068,1): Raster map <TIN280911 at GurobDEM> not
> found
> > GRASS_INFO_END(6068,1)
> > GRASS_INFO_WARNING(6068,2): Raster map <TIN280911 at GurobDEM> not
> found
> > GRASS_INFO_END(6068,2)
> > GRASS_INFO_WARNING(6068,3): can't read f_range file for
> > [TIN280911 at GurobDEM in ]
> > GRASS_INFO_END(6068,3)
> > GRASS_INFO_ERROR(6068,4): Unable to read range file
> > GRASS_INFO_END(6068,4)
> > At this point, QGIS stops running and has to be closed.
> > I am runnning Windows 7 64 bit.
> > Hannah
> > Qgis-user mailing list
> > Qgis-user at xxxxxxxxxxxxxxx
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
