[Qgis-user] Problem importing raster file
Anna Hodgkinson
anna.hodgkinson at thehumanjourney.net
Wed Nov 23 04:01:21 PST 2011
Hi Jay,
Yes, this has been resolved. Did you use the option to "Import loaded raster and create fitted location"?
Then:
Instead of selecting to view the imported raster in the current location, which brings up that error, you must first close your GRAS toolbox, then go to "Open mapset" and select the new location you just created using that raster.
Then you should be able to add that raster layer to your QGIS project.
This worked for Hannah, and I managed to replicate the problem by simply hitting "View results" at the end of the import process.
Just open the new location you just created.
Hope this helps.
All the best,
Anna
______________________________________________
Anna Kathrin Hodgkinson MA MSt (Oxon) AIFA EES
Supervisor Geomatics
Oxford Archaeology: Exploring the Human Journey
Mobile: +44 (0)7906 638308 (personal)
Direct Dial: +44 (0)1865 980 855
http://thehumanjourney.net
----- Original Message -----
Date: Tue, 22 Nov 2011 10:10:40 -0500 (EST)
Subject: [Qgis-user] Problem importing raster file
To: qgis-user at lists.osgeo.org
Message-ID:
<1628233293.114543.1321974640678.JavaMail.root at simcoe.cs.uoguelph.ca>
Content-Type: text/plain; charset=utf-8
Hi, I've been stuck on a problem for a few days now and could really use
some help. I'm having the same problem reported in a previous post
(Included below). Does anybody have suggestions to why this error
(unable to read range file) may be occuring and how it can be fixed?
Thanks,
Jay
Subject: Re: [Qgis-user] Problem with QGIS importing raster
into GRASS - msg#00134
List: qgis-user-gis
Mail Archive Navigation:
by Date: Prev Date Index by Thread: Prev Next Thread Index
I just tested to import your raster and I had no problems whatsoever
when adding it to the QGIS canvas.
Cheers
-- Giovanni --
On Wed, 2011-10-12 at 04:08 -0700, Hannah Pethen wrote:
> Hi
> The raster is attached.
> I should clarify that the data is in a 'local' grid, and so cannot be
> tied to a known co-ordinate system. The co-ordinate system chosen for
> the GRASS mapset (British National Grid) is for expediency. As the
> co-ordinates of the local grid are still within the numerical
> parameters of the British National Grid co-ordinate system (i.e. it
> still appears within the red 'location ' box), I cannot see that this
> should cause it to fail when projecting but if it has, any thoughts on
> how to correct it would be appreciated.
> Thanks
> Hannah
> From: Giovanni Manghi <giovanni.manghi at xxxxxxxxx>
> To: Hannah Pethen <hannahpethen at xxxxxxxxx>
> Cc: "qgis-user at xxxxxxxxxxxxxxx" <qgis-user at xxxxxxxxxxxxxxx>
> Sent: Monday, October 10, 2011 10:17 PM
> Subject: Re: [Qgis-user] Problem with QGIS importing raster into GRASS
> Hi,
> I just tested in my Windows Seven 64 bit VM with qgis-dev/osgeo4w and
> I cannot replicate it.
> Can you share one of the rasters which is causing the crash?
> Cheers
> -- Giovanni --
> On Mon, 2011-10-10 at 13:45 -0700, Hannah Pethen wrote:
> > Dear All
> > I am experiencing problems importing rasters from QGIS into GRASS
> > using the GRASS toolbox in QGIS. Having created a new location and
> > mapset, I attempt to import my raster into GRASS using the toolbox
> in
> > QGIS. When I run the r.in.gdal command, the raster is sucessfully
> > created but when I click on 'View Output' I get the following error
> > message:
> > Cannot get map info
> > Cannot run module
> > command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.g.info
> > info=info rast=TIN280911 at GurobDEM<br>TYPE:-1
> > <br> GRASS_INFO_WARNING(6068,1): Raster map <TIN280911 at GurobDEM> not
> found
> > GRASS_INFO_END(6068,1)
> > GRASS_INFO_WARNING(6068,2): Raster map <TIN280911 at GurobDEM> not
> found
> > GRASS_INFO_END(6068,2)
> > GRASS_INFO_WARNING(6068,3): can't read f_range file for
> > [TIN280911 at GurobDEM in ]
> > GRASS_INFO_END(6068,3)
> > GRASS_INFO_ERROR(6068,4): Unable to read range file
> > GRASS_INFO_END(6068,4)
> > At this point, QGIS stops running and has to be closed.
> > I am runnning Windows 7 64 bit.
> > Hannah
> > _______________________________________________ Qgis-user mailing
> > list Qgis-user at xxxxxxxxxxxxxxx
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
This email has been processed by SmoothZap - www.smoothwall.net
