[Qgis-user] Style Layer Descriptor support
Alex Mandel
tech_dev at wildintellect.com
Wed Nov 23 00:17:45 PST 2011
On 11/22/2011 07:13 AM, Lars Burman wrote:
> Hello!
> I have made an WMS-service using ArcGIS-server. It is 4 layers, 3 with
> polygons and every layer has a certain color, the 4th layer is labels for
> the polygons.
> With the service I made an .SLD file becuase I wanted to pick certain
> colors and I wanted transparency for the polygons and I wanted to decided
> on what scale to show the labels. I want it to be 1:500 000 and closer.
> Everything works fine, I can consume the service in Qgis 1.7.1, I can see
> the layers and labels, and they have the colors I wanted. But two things do
> not work, the transparency and the set scale. This however works if I
> consume the service in ArcMap.
> *I guess my question is, does QGis support the ArcGIS .SLD?*
> This is my code, under the element <rule> - <PolygonSymbolizer> - <Fill>
> <sld:CssParameter name="fill">#D23262</sld:CssParameter>
> <sld:CssParameter name="fill-opacity">0.5</sld:CssParameter>
> <MinScaleDenominator>0</MinScaleDenominator>
> <MaxScaleDenominator>1000000</MaxScaleDenominator>
> Any idéas?
> Thanks!
> Regards, Lars
Good question, I have transparency working fine on my WMS layers but I'm
serving them from Geoserver. I wonder what the difference is? Although
I'm not doing scale dependent rendering either.
What happens if you just apply transparency at all scales? Does that
work? Do other examples of scale dependent rendering work for things
other than transparency?
Thanks,
Alex
