[Qgis-user] Re: [Qgis-developer] Critical problems with 1.7.2 from ubuntu binaries
Etienne Tourigny
etourigny.dev at gmail.com
Wed Nov 30 05:45:19 PST 2011
shouldn't qgis be packaged in such a way to avoid multiple (minor)
versions of QGIS?
i.e. change the package names to 1.7 instead of 1.7.0 / 1.7.1 / 1.7.2 ?
There really is no need to have the old packages around, especially
with this issue.
Regards,
Etienne
On Tue, Nov 29, 2011 at 8:09 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> reproduced the problem by installing on another machine with ubuntu
>> 10.04 . Running qgis from the command line I get:
>> alobo at delia:~$ qgis
>> Warning: loading of qgis translation failed
>> [/usr/share/qgis/i18n//qgis_en_US]
>> Warning: loading of qt translation failed
>> [/usr/share/qt4/translations/qt_en_US]
>> Warning: Couldn't load Python support library: Cannot load library
>> /lib/qgispython: (/lib/libqgispython.so: cannot open shared object
>> file: No such file or directory)
> In ubuntu 10.04 Lucid, you have to install
> - python-qgis 1.7.2~Lucid1
> - python-qgis-common 1.7.2-1~Lucid1
> If you upgrade from other version (e.g. 1.7.0), you have to remove
> first the old version then install 1.7.2.
> Noli
> Qgis-developer mailing list
