[Qgis-user] Re: [Qgis-developer] Critical problems with 1.7.2 from ubuntu binaries
David J. Bakeman
dbakeman at comcast.net
Wed Nov 30 11:21:24 PST 2011
Etienne Tourigny wrote:
> shouldn't qgis be packaged in such a way to avoid multiple (minor)
> versions of QGIS?
> i.e. change the package names to 1.7 instead of 1.7.0 / 1.7.1 / 1.7.2 ?
> There really is no need to have the old packages around, especially
> with this issue.
I respectfully disagree. It's not that the old packages need to be
around it's that they are
out there already. People have them some people either can't or won't
be able to upgrade
them and when those people have questions it's important that the
developers and others
know exactly what version of the software is being discussed.
> Regards,
> Etienne
> On Tue, Nov 29, 2011 at 8:09 AM, Noli Sicad<nsicad at gmail.com> wrote:
>>> reproduced the problem by installing on another machine with ubuntu
>>> 10.04 . Running qgis from the command line I get:
>>> alobo at delia:~$ qgis
>>> Warning: loading of qgis translation failed
>>> [/usr/share/qgis/i18n//qgis_en_US]
>>> Warning: loading of qt translation failed
>>> [/usr/share/qt4/translations/qt_en_US]
>>> Warning: Couldn't load Python support library: Cannot load library
>>> /lib/qgispython: (/lib/libqgispython.so: cannot open shared object
>>> file: No such file or directory)
>> In ubuntu 10.04 Lucid, you have to install
>> - python-qgis 1.7.2~Lucid1
>> - python-qgis-common 1.7.2-1~Lucid1
>> If you upgrade from other version (e.g. 1.7.0), you have to remove
>> first the old version then install 1.7.2.
>> Noli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Qgis-user mailing list
