[Qgis-user] Re: Mac OS X, Sextante and other plugins or the forgotten users..
Noli Sicad
nsicad at gmail.com
Sun Apr 1 03:57:59 PDT 2012
I did what you outlined, SEXTANTE is not showing.
Could you just tell me what is the URL of the QGIS Official Repository 2?
Just click Edit and you will see the URL, the second line.
Thanks.
Noli
On 4/1/12, Julian Bogdani <jbogdani at gmail.com> wrote:
> In QGIS:
> Plugins > Fetch Python Plugins
> Repositories: "Add third party repositories"
> Options: select "Show all, even those marked as experimental"
> Plugins: filter type sextante
> You'll see it in the list (under repository you'll find QGIS Official
> Repository 2), go ahead and install.
> Julian Bogdani
> http://bradypus.net
> On 1 Apr 2012, at 12:34 , Noli Sicad wrote:
>> What is the QGIS Official Repository 2, could give details on this.
>> It seems that I am not getting SEXTANTE as well in my Mac OS X QGiS.
>> Thanks.
>> Noli
>>> Hello,
>>> I'm running QGIS on MacOS also, and having problems with SEXTANTE. I was
>>> able to successfully install it from the QGIS Official Repository 2, but
>>> SAGA does not work.
>>> Here is the log for a simple points to lines analysis:
>>> ALGORITHM|Sun Apr 01 2012
>>> 12:16:46|Sextante.runalg("saga:convertpointstoline(s)","/Users/jbogdani/qgis/points.shp","cat1","cat2",None)
>>> INFO|Sun Apr 01 2012 12:16:46|SAGA execution commands|libshapes_lines
>>> "Convert Points to Line(s)" -POINTS /Users/jbogdani/qgis/points.shp
>>> -ORDER
>>> "cat1" -SEPARATE "cat2" -LINES
>>> /Users/jbogdani/sextante/tempdata/1333275406.0329.shp
>>> INFO|Sun Apr 01 2012 12:16:46|SAGA execution console
>>> output|/Users/jbogdani/sextante/saga_batch_job.sh: line 1: saga_cmd:
>>> command
>>> not found
>>> Julian Bogdani
>>> http://bradypus.net
>>> On 1 Apr 2012, at 12:09 , gene wrote:
>>>> I installed this plugin (and before the experimental 0.1 from
>>>> http://code.google.com/p/sextante/source/browse/#svn%2Ftrunk%2Fsoft%2Fbindings%2Fqgis-plugin
>>>> ) otherwise I could not say that it not works with SAGA or R.
>>>> View this message in context:
>>>> http://osgeo-org.1560.n6.nabble.com/Mac-OS-X-Sextante-and-other-plugins-or-the-forgotten-users-tp4676106p4676150.html
>>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
