[Qgis-user] Re: Printing
Alexandre Neto
senhor.neto at gmail.com
Wed Apr 4 11:34:04 PDT 2012
Hello,
Instead of exporting to PDF, try to use a PDF printer like Cute PDF, it
worked for me once.
Alexandre Neto
On Wed, Apr 4, 2012 at 5:13 PM, Giovanni Manghi <giovanni.manghi at faunalia.pt
> wrote:
> On Wed, 2012-04-04 at 01:47 -0700, Glen Ossman wrote:
> > ok even with setting the scale the points never line up
> > on the map they show correctly but when i use the print composer and try
> > ever scale the points won't line up. this has to be a bug
> yes, it seems you are right and that is a known issue
> http://hub.qgis.org/projects/openlayers/issues?set_filter=1&tracker_id=1
> anyway it is not a qgis issue (the tool is a 3rd party plugin) and
> there are workarounds, like taking a snapshot of the map portion you
> need and use it as a normal raster (but I don't know if the google
> licence allows such kind of things).
> cheers
> -- Giovanni --
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120404/20dac08f/attachment.html>
