[Qgis-user] QGIS Crash on Opening Project
Lee muellerl at gmail.com
Mon Apr 16 10:30:11 PDT 2012
I was able to fix the issue by first removing all the openlayers. I then
switched the file locations from absolute to relative. Everything seems to
be working.
Thanks.
all the best,
Lee Mueller
ISA Certified Arborist
Registered Forester #46043
On Mon, Apr 16, 2012 at 1:18 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
> I've have heard recently of projects crashing on failure to find some
> layers. Can you open the qgs project file (It's a text file) and verify
> that the paths it's trying to search work. I can see if samba/windows
> shares are involved that your ubuntu system might not be resolving them
> correctly. So you might want to verify that you can file browse to the data
> locations 1st.
> Thanks,
> Alex
> On 04/13/2012 02:38 PM, Lee wrote:
>> Some projects do include an openlayer layer. Others do not. It crashes
>> with
>> either.
>> all the best,
>> Lee Mueller
>> On Fri, Apr 13, 2012 at 2:31 PM, Zoran Janković
>> <zoran.m.jankovic at gmail.com>**wrote:
>>  Hi,
>>> I got similar behaviour on Windows boxes (1.7.4) when using (or, rather,
>>> trying to use) OpenLayers plugin, or opening an existing project with
>>> Openlayers layer inside... So far, no solution, it is on the bug
>>> tracklist... Are you using this plugin?
>>> BR,
>>> Zoran
>>> Dana petak, 13. travnja 2012., korisnik Lee je napisao:
>>> Gang,
>>>> I have been using QGIS at my workplace on our windows cloud. I have
>>>> developed several project files which use various shapefiles located on
>>>> our
>>>> server. QGIS works fine when using it on windows to access these files.
>>>> Recently, I was able to crash our cloud while attempting to perform some
>>>> operations on rather large datasets. They have since moved me off the
>>>> cloud
>>>> to my own computer. Naturally, I requested Ubuntu. Unfortunately, when I
>>>> map our server drives to my machine and attempt to open my QGIS files, I
>>>> first get the general warning about "earlier versions of QGIS" before
>>>> the
>>>> layers start to load and QGIS crashes completely.
>>>> To fix this, I attempted to copy the entire folder which houses the
>>>> projects onto my desktop and load the projects away from the server.
>>>> Unfortunately, this has caused the same crash. No errors. No warning.
>>>> Just
>>>> a complete closing of QGIS.
>>>> Finally, I tried running it through the terminal to see what kind of
>>>> error's might be generated. This time, it did not crash completely but
>>>> gave an "std::bad_alloc" error. The terminal output for the session is
>>>> as
>>>> follows:
>>>> lee at lee-desktop:~$ qgis
>>>> Warning: loading of qgis translation failed
>>>> [/usr/share/qgis/i18n//qgis_**en_US]
>>>> Warning: loading of qt translation failed
>>>> [/usr/share/qt4/translations/**qt_en_US]
>>>> Python support ENABLED :-)
>>>> Loaded : Plugin Installer (package: plugin_installer)
>>>> Loaded : fTools (package: fTools)
>>>> Warning: Loading a file that was saved with an older version of qgis
>>>> (saved in 1.7.0-Wroclaw, loaded in 1.7.4-Wroclaw). Problems may occur.
>>>> I see no errors, or output outside of the ordinary. Again, a direct
>>>> opening from a file produces a crash, through terminal produces an
>>>> error.
>>>> Has anyone experienced a similar issue? Any suggestions for a fix or
>>>> work-around?
>>>> Thank you in advance.
>>>> all the best,
>>>> Lee Mueller
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120416/e0da3b74/attachment.html>
