[Qgis-user] QGIS Crash on Opening Project
Alex Mandel
tech_dev at wildintellect.com
Mon Apr 16 10:18:47 PDT 2012
I've have heard recently of projects crashing on failure to find some
layers. Can you open the qgs project file (It's a text file) and verify
that the paths it's trying to search work. I can see if samba/windows
shares are involved that your ubuntu system might not be resolving them
correctly. So you might want to verify that you can file browse to the
data locations 1st.
Thanks,
Alex
On 04/13/2012 02:38 PM, Lee wrote:
> Some projects do include an openlayer layer. Others do not. It crashes with
> either.
> all the best,
> Lee Mueller
> ISA Certified Arborist
> Registered Forester #46043
> On Fri, Apr 13, 2012 at 2:31 PM, Zoran Janković
> <zoran.m.jankovic at gmail.com>wrote:
>> Hi,
>> I got similar behaviour on Windows boxes (1.7.4) when using (or, rather,
>> trying to use) OpenLayers plugin, or opening an existing project with
>> Openlayers layer inside... So far, no solution, it is on the bug
>> tracklist... Are you using this plugin?
>> BR,
>> Zoran
>> Dana petak, 13. travnja 2012., korisnik Lee je napisao:
>> Gang,
>>> I have been using QGIS at my workplace on our windows cloud. I have
>>> developed several project files which use various shapefiles located on our
>>> server. QGIS works fine when using it on windows to access these files.
>>> Recently, I was able to crash our cloud while attempting to perform some
>>> operations on rather large datasets. They have since moved me off the cloud
>>> to my own computer. Naturally, I requested Ubuntu. Unfortunately, when I
>>> map our server drives to my machine and attempt to open my QGIS files, I
>>> first get the general warning about "earlier versions of QGIS" before the
>>> layers start to load and QGIS crashes completely.
>>> To fix this, I attempted to copy the entire folder which houses the
>>> projects onto my desktop and load the projects away from the server.
>>> Unfortunately, this has caused the same crash. No errors. No warning. Just
>>> a complete closing of QGIS.
>>> Finally, I tried running it through the terminal to see what kind of
>>> error's might be generated. This time, it did not crash completely but
>>> gave an "std::bad_alloc" error. The terminal output for the session is as
>>> follows:
>>> lee at lee-desktop:~$ qgis
>>> Warning: loading of qgis translation failed
>>> [/usr/share/qgis/i18n//qgis_en_US]
>>> Warning: loading of qt translation failed
>>> [/usr/share/qt4/translations/qt_en_US]
>>> Python support ENABLED :-)
>>> Loaded : Plugin Installer (package: plugin_installer)
>>> Loaded : fTools (package: fTools)
>>> Warning: Loading a file that was saved with an older version of qgis
>>> (saved in 1.7.0-Wroclaw, loaded in 1.7.4-Wroclaw). Problems may occur.
>>> I see no errors, or output outside of the ordinary. Again, a direct
>>> opening from a file produces a crash, through terminal produces an error.
>>> Has anyone experienced a similar issue? Any suggestions for a fix or
>>> work-around?
>>> Thank you in advance.
>>> all the best,
>>> Lee Mueller
