[Qgis-user] Re: qgis-server problem with spatialite layers
jbogdani
jbogdani at gmail.com
Fri Apr 20 12:50:25 PDT 2012
UPDATE:
I made some more tests with a second Ubuntu server (a desktop version). It
seems it's a path problem.
On MacOS a spatialite layer can be added using generic "Add vector layer" or
specific add "SpatiaLite layer". Both procedures work. On ubuntu the first
procedure does not work: loads up a layer, but nothing is showed on the map;
this was my case.
Adding the layer following the second procedure does show the layer in the
map in Qgis, but did not work for qgis-web-client. Switching the project to
absolute path, works.
As a conclusion there is no way to get spatiaLite work with relative paths.
Not in my case. Can anyone confirm? And, why there is such a render
difference in MacOS and Linux, with spatiaLite added as vector layer?
jbogdani wrote
> hello all,
> I'm experiencing a very strange behavior of qgis-server with spatialite
> layers. I'm testing it on my MacBook (snow leopard) and on a Ubuntu
> server.
> Using shapefiles the project loads fine; using spatialite I can
> successfully view the map on qgis-web-client using MacOS as server, but no
> map is shown with Ubuntu server. I can see the layer list, but no feature
> in the map.
> Adding other layers, raster and shapefiles, I get a mix result in Ubuntu:
> shapefiles & rasters are correctly displayed, but no spatialite layer is
> displayed.
> I created the spatialite layers using QspatiaLite plugin.
> Qgis-web-client' test project, wich uses spatialite, is correctly showed!
> Any help?
> Julian Bogdani
> jbogdani@
> http://bradypus.net
> Qgis-user mailing list
> Qgis-user at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/qgis-server-problem-with-spatialite-layers-tp4902421p4903190.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
