[Qgis-user] Re: qgis-server problem with spatialite layers
Marco Hugentobler marco.hugentobler at sourcepole.ch
Sat Apr 21 08:20:25 PDT 2012
Hi Julian
Spatialite layers with relativ pathes work fine for me in QGIS server
with the current developer version (on ubuntu 11.10).
Which version of QGIS are you using? I remember having added the
relative -> absolute path conversion for file based databases some time ago.
Probably you are using different versions on Mac OS and Linux?
Regards,
Marco
On 20.04.2012 21:50, jbogdani wrote:
> UPDATE:
> I made some more tests with a second Ubuntu server (a desktop version). It
> seems it's a path problem.
> On MacOS a spatialite layer can be added using generic "Add vector layer" or
> specific add "SpatiaLite layer". Both procedures work. On ubuntu the first
> procedure does not work: loads up a layer, but nothing is showed on the map;
> this was my case.
> Adding the layer following the second procedure does show the layer in the
> map in Qgis, but did not work for qgis-web-client. Switching the project to
> absolute path, works.
> As a conclusion there is no way to get spatiaLite work with relative paths.
> Not in my case. Can anyone confirm? And, why there is such a render
> difference in MacOS and Linux, with spatiaLite added as vector layer?
> jbogdani wrote
>> hello all,
>> I'm experiencing a very strange behavior of qgis-server with spatialite
>> layers. I'm testing it on my MacBook (snow leopard) and on a Ubuntu
>> server.
>> Using shapefiles the project loads fine; using spatialite I can
>> successfully view the map on qgis-web-client using MacOS as server, but no
>> map is shown with Ubuntu server. I can see the layer list, but no feature
>> in the map.
>> Adding other layers, raster and shapefiles, I get a mix result in Ubuntu:
>> shapefiles&  rasters are correctly displayed, but no spatialite layer is
>> displayed.
>> I created the spatialite layers using QspatiaLite plugin.
>> Qgis-web-client' test project, wich uses spatialite, is correctly showed!
>> Any help?
>> Julian Bogdani
>> jbogdani@
>> http://bradypus.net
>> Qgis-user mailing list
>> Qgis-user at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> View this message in context: http://osgeo-org.1560.n6.nabble.com/qgis-server-problem-with-spatialite-layers-tp4902421p4903190.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
