[Qgis-user] Re: qgis-server problem with spatialite layers
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Sat Apr 21 08:40:49 PDT 2012
Hi Julian
Version 1.7.4 has the bug with relative pathes for spatialite not
supported in QGIS server. The most recent source code (=upcoming 1.8)
works fine.
>What do you mean when you write: " I remember having added the
relative -> absolute path >conversion for file based databases some time
ago."? You do not mean the "Save paths" in Project >properties, do you?
No, I meant the path conversion in QGIS server.
Regards,
Marco
On 21.04.2012 17:29, Julian Bogdani wrote:
> I'm running Qgis 1.7.4 both on MacOS and on Ubuntu (10.04.4).
> I'll try tomorrow also with Ubuntu 11, same QGIS.
> relative -> absolute path conversion for file based databases some
> time ago."? You do not mean the "Save paths" in Project properties, do
> you?
> Julian Bogdani
> jbogdani at gmail.com <mailto:jbogdani at gmail.com>
> http://bradypus.net
> On 21 Apr 2012, at 17:20 , Marco Hugentobler wrote:
>> Hi Julian
>> Spatialite layers with relativ pathes work fine for me in QGIS server
>> with the current developer version (on ubuntu 11.10).
>> Which version of QGIS are you using? I remember having added the
>> time ago.
>> Probably you are using different versions on Mac OS and Linux?
>> Regards,
>> Marco
>> On 20.04.2012 21:50, jbogdani wrote:
>>> UPDATE:
>>> I made some more tests with a second Ubuntu server (a desktop
>>> version). It
>>> seems it's a path problem.
>>> On MacOS a spatialite layer can be added using generic "Add vector
>>> layer" or
>>> specific add "SpatiaLite layer". Both procedures work. On ubuntu the
>>> first
>>> procedure does not work: loads up a layer, but nothing is showed on
>>> the map;
>>> this was my case.
>>> Adding the layer following the second procedure does show the layer
>>> in the
>>> map in Qgis, but did not work for qgis-web-client. Switching the
>>> project to
>>> absolute path, works.
>>> As a conclusion there is no way to get spatiaLite work with relative
>>> paths.
>>> Not in my case. Can anyone confirm? And, why there is such a render
>>> difference in MacOS and Linux, with spatiaLite added as vector layer?
>>> jbogdani wrote
>>>> hello all,
>>>> I'm experiencing a very strange behavior of qgis-server with spatialite
>>>> layers. I'm testing it on my MacBook (snow leopard) and on a Ubuntu
>>>> server.
>>>> Using shapefiles the project loads fine; using spatialite I can
>>>> successfully view the map on qgis-web-client using MacOS as server,
>>>> but no
>>>> map is shown with Ubuntu server. I can see the layer list, but no
>>>> feature
>>>> in the map.
>>>> Adding other layers, raster and shapefiles, I get a mix result in
>>>> Ubuntu:
>>>> shapefiles& rasters are correctly displayed, but no spatialite
>>>> layer is
>>>> displayed.
>>>> I created the spatialite layers using QspatiaLite plugin.
>>>> Qgis-web-client' test project, wich uses spatialite, is correctly
>>>> showed!
>>>> Any help?
>>>> Julian Bogdani
>>>> jbogdani@
>>>> http://bradypus.net
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at .osgeo
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> View this message in context:
>>> http://osgeo-org.1560.n6.nabble.com/qgis-server-problem-with-spatialite-layers-tp4902421p4903190.html
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com
>>> <http://Nabble.com>.
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> Dr. Marco Hugentobler
>> Sourcepole - Linux& Open Source Solutions
>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>> <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120421/dba3fc2a/attachment.html>
