[Qgis-user] Estimating elevation points from contour data
Giovanni Manghi giovanni.manghi at faunalia.pt
Mon Apr 23 08:41:34 PDT 2012
use the interpolation tool to get a digital elevation model from your
contour lines, then use the "point sampling tool" to sample the dem
using the points.
cheers
-- Giovanni --
On Mon, 2012-04-23 at 16:38 +0100, Des Callaghan wrote:
> Hello Forum,
> I have a layer with point locations and another layer with 5 m
> elevation contours. I wish to estimate the elevation of each point
> from the data within the contour layer. I have a new column within the
> point layer table so just need to know how I can update this column
> with an elevation estimate for each point derived from the contour
> layer. Any ideas how this may be done?  Many thanks for any help.
> Best wishes,
> Des
> Qgis-user mailing list
