[Qgis-user] Re: Estimating elevation points from contour data
Nick Hopton
nhopton at gmail.com
Tue Apr 24 02:06:53 PDT 2012
Hi Des, rather than using your contour data to make a DEM you might be better
off with OS OpenData DTMs and using the point sampling tool on these (you're
after what, spot heights?).
Where the landform hasn't changed since back in the Neolithic when the OS
DTMs were made they're not bad.
Nick.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Estimating-elevation-points-from-contour-data-tp4910663p4912903.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
