[Qgis-user] Acess to ArcIMS server with QGIS.
Noli Sicad nsicad at gmail.com
Sun Apr 29 18:01:19 PDT 2012
Hi Kerick,
You can probably hack the QGIS Openlayers plugin and incorporate
ArcIMS openlayers script in it.
Please note that the Openlayers scripts for ArcIMS are just adding
layers from ArcIMS server. No edits on it. This also applies to QGIS
Openlayers plugin.
Noli
On 4/30/12, Alex Mandel <tech_dev at wildintellect.com> wrote:
> On 04/29/2012 07:20 AM, Kerick Leite wrote:
>> Is there some way to acess a ArcIMS server from within QGIS? I've done
>> some
>> research in the web, and could find some indications it can be done with
>> Openlayers(refs. 1,2), but I didn't find any specific instructions on how
>> to do it.
>> The server in question is located at maps.bdep.gov.br, and often I need
>> to
>> acess it due to work. In ArcGIS its possible to add the server as a
>> source
>> in arcinfo, and visualize and work with the layers directly. But I could
>> not find how to do the same in QGIS, and end having to download each
>> layer
>> beforehand, what is quite cumbersome.
>> References:
>> 1 -
>> http://www.geowebdeveloper.com/2009/04/13/arcims-support-for-openlayers/
>> 2 -
>> http://download.osgeo.org/qgis/doc/presentation/bern2010/qgis_bern_2010_openlayers_plugin.pdf
>> Thanks,
>> Kerick
> If it supports any of the OGC standards then it's easy (eg. WMS, WFS,
> etc). I don't think they added those until ArcGIS Server though. To find
> running ArcIMS machines is kinda rare. I imagine there are some hacks to
> get at the data.
> The reality is you might need to download ahead of time or take the
> openlayers ArcIMS code and tweak it to work similar to the WMS code in
> QGIS.
> Good Luck,
> Alex
> Qgis-user mailing list
