[Qgis-user] Dissolve function with various modules
skampus
stefano.campus at regione.piemonte.it
Sun Aug 19 17:15:38 PDT 2012
I'm trying to dissove a shape file of polygons as results of voronoi diagram
made by sextante mmqgisx.
three modules are in sextante and none works
1) saga
two options used (with inner boundaries and without): the boundaries still
exist
2) ftools: the resulting polygon is empty
Dissolve instance has no attribute 'myParam'
File
"C:/Users/skampus/.qgis//python/plugins\sextante\core\GeoAlgorithm.py", line
116, in execute
self.processAlgorithm(progress)
File "C:/Users/skampus/.qgis//python/plugins\sextante\ftools\Dissolve.py",
line 141, in processAlgorithm
tempItem = atMap[ self.myParam ]
AttributeError: Dissolve instance has no attribute 'myParam'
3) grass: it seems that it does the work but an error occurs at the end
the configuration region is set as default, "use min covering region"
activated
4) ftoos from vector menu: error in creating output
5) arcgis: it works :-(
QGIS 1.8
Sextante 353
http://osgeo-org.1560.n6.nabble.com/file/n4996229/dissolve_dataset.zip
View this message in context: http://osgeo-org.1560.n6.nabble.com/Dissolve-function-with-various-modules-tp4996229.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
