[Qgis-user] How to open external links, interpret css or JavaScript from a WMS getFeatureInfo result
Jürgen E. Fischer
jef at norbit.de
Fri Dec 7 00:06:23 PST 2012
Hi Astrid,
On Fri, 07. Dec 2012 at 09:50:19 +0100, Astrid Emde wrote:
> I am using WMS in QGIS and get Information about my data through the
> getFeatureInfo-request. In the html-result of the request I have links to
> other websides or scripts and I refer to an external css-file.
> Unfortunately QGIS does not open the links and does not use the css.
Which version are you referring to? In master you should be able to follow
links. You can also print HTML responses.
> Looks like QGIS ignores the JavaScript Code too?
> Is there a possibility to enable QGIS to open the links,use the css and
> interpret JavaScript?
Not sure. QGIS uses Qt's internal webkit to render the page. Do you have a
public sample server to try that with?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
committ(ed|ing) to Quantum GIS IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
