[Qgis-user] How to open external links, interpret css or JavaScript from a WMS getFeatureInfo result
Astrid Emde
astrid.emde at wheregroup.com
Wed Dec 12 00:35:32 PST 2012
Am 07.12.2012 09:06, schrieb Jürgen E. Fischer:
> Hi Astrid,
> On Fri, 07. Dec 2012 at 09:50:19 +0100, Astrid Emde wrote:
>> I am using WMS in QGIS and get Information about my data through the
>> getFeatureInfo-request. In the html-result of the request I have links to
>> other websides or scripts and I refer to an external css-file.
>> Unfortunately QGIS does not open the links and does not use the css.
> Which version are you referring to? In master you should be able to follow
> links. You can also print HTML responses.
>> Looks like QGIS ignores the JavaScript Code too?
>> Is there a possibility to enable QGIS to open the links,use the css and
>> interpret JavaScript?
> Not sure. QGIS uses Qt's internal webkit to render the page. Do you have a
> public sample server to try that with?
> Jürgen
Hello Jürgen,
you could take this WMS to test.
https://lx-gis.stadt.wolfsburg.de/cgi-bin/mapserv?map=/gds/map/stadtteilgrenzen_extern.map&VERSION=1.1.1
The inforesult should contain an external image. But maybe this already
works with the master... I did not test with the master yet.
Best regards
Astrid Emde
Where2B Konferenz 2012
13. Dezember 2012 in Bonn
www.where2b-conference.com
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
