[Qgis-user] How to open external links, interpret css or JavaScript from a WMS getFeatureInfo result
Jürgen E. Fischer
jef at norbit.de
Wed Dec 12 02:41:32 PST 2012
Moin Astrid,
On Wed, 12. Dec 2012 at 09:35:32 +0100, Astrid Emde wrote:
> >> Looks like QGIS ignores the JavaScript Code too?
> >> Is there a possibility to enable QGIS to open the links,use the css and
> >> interpret JavaScript?
> > Not sure. QGIS uses Qt's internal webkit to render the page. Do you have
> > a public sample server to try that with?
> you could take this WMS to test.
> https://lx-gis.stadt.wolfsburg.de/cgi-bin/mapserv?map=/gds/map/stadtteilgrenzen_extern.map&VERSION=1.1.1
> The inforesult should contain an external image. But maybe this already
> works with the master... I did not test with the master yet.
There were two problems with that: External images didn't work at all and also
references to SSL sites without a verifyable certificate didn't work.
With c7fb23079 it works now. At the same time I also reworked the context
menu so that the print entry is now added to the default menu (instead of
replacing it completely) and enabled the "Inspect" entry in debug builds.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
committ(ed|ing) to Quantum GIS IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
