[Qgis-user] How to open external links, interpret css or JavaScript from a WMS getFeatureInfo result
Astrid Emde
astrid.emde at wheregroup.com
Wed Dec 12 04:37:30 PST 2012
Am 12.12.2012 11:41, schrieb Jürgen E. Fischer:
> Moin Astrid,
> On Wed, 12. Dec 2012 at 09:35:32 +0100, Astrid Emde wrote:
>>>> Looks like QGIS ignores the JavaScript Code too?
>>>> Is there a possibility to enable QGIS to open the links,use the css and
>>>> interpret JavaScript?
>>> Not sure. QGIS uses Qt's internal webkit to render the page. Do you have
>>> a public sample server to try that with?
>> you could take this WMS to test.
>> https://lx-gis.stadt.wolfsburg.de/cgi-bin/mapserv?map=/gds/map/stadtteilgrenzen_extern.map&VERSION=1.1.1
>> The inforesult should contain an external image. But maybe this already
>> works with the master... I did not test with the master yet.
> There were two problems with that: External images didn't work at all and also
> references to SSL sites without a verifyable certificate didn't work.
> With c7fb23079 it works now. At the same time I also reworked the context
> menu so that the print entry is now added to the default menu (instead of
> replacing it completely) and enabled the "Inspect" entry in debug builds.
> Jürgen
Hello Jürgen,
thanks a lot for the Bug fix. I will test the solution an give feedback.
Best regards
Astrid Emde
Where2B Konferenz 2012
13. Dezember 2012 in Bonn
www.where2b-conference.com
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
