[Qgis-user] shp*join*csv real2string problem
magerlin
MAP at ramboll.dk
Sun Dec 9 01:41:21 PST 2012
Hi
It's pretty simple - if you just know it....
To define how Myfile.csv is read make a Myfile.csvt file (I guess the extra
t means Template) and put it in the same folder as the csv file.
It is a simple one line text file with one entry for every column in your
csv file telling Qgis how to read it:
"Integer(6)","Real(5.5)","String(22)" .....
You can leave out the numbers and () if you like.
Regards Morten
Qgis 1.8.0 Stand alone installer in Win7 64 bit
View this message in context: http://osgeo-org.1560.n6.nabble.com/shp-join-csv-real2string-problem-tp5021602p5021655.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
