[Qgis-user] Cannot add sqlite/spatialite layers to qgis (they come in as tables)
Donovan Cameron
sault.don at gmail.com
Sun Dec 9 11:12:15 PST 2012
Forgot to mention that tutorial link for reference:
http://www.gaia-gis.it/gaia-sins/spatialite-tutorial-2.3.1.html#t3
On Sun, Dec 9, 2012 at 12:11 PM, Donovan Cameron <sault.don at gmail.com>wrote:
> Thanks alex, that's definitely helpful.
> I tried to install pyspatialite with easy_install and it tries to grab
> "Best match: pyspatialite 3.0.1" which fails with a lot of errors...
> I can run through the tutorials from the spatialite page and this is the
> initial output, telling me I am using spatialite 4:
> SpatiaLite version ..: 4.0.0 Supported Extensions:
> - 'VirtualShape' [direct Shapefile access]
> - 'VirtualDbf' [direct DBF access]
> - 'VirtualXL' [direct XLS access]
> - 'VirtualText' [direct CSV/TXT access]
> - 'VirtualNetwork' [Dijkstra shortest path]
> - 'RTree' [Spatial Index - R*Tree]
> - 'MbrCache' [Spatial Index - MBR cache]
> - 'VirtualSpatialIndex' [R*Tree metahandler]
> - 'VirtualFDO' [FDO-OGR interoperability]
> - 'SpatiaLite' [Spatial SQL - OGC]
> PROJ.4 version ......: Rel. 4.8.0, 6 March 2012
> GEOS version ........: 3.3.6-CAPI-1.7.6
> SQLite version ......: 3.7.12.1
> I only installed QGIS from the GEO openSUSE repo.
> I wonder if this is a dependency issue for the package maintainers?
> I have a freshly installed 12.2 KDE on a laptop and that also shows the
> same output from above when creating a new sqlite db from spatialite.
> On Sun, Dec 9, 2012 at 12:00 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>> On 12/09/2012 10:40 AM, Donovan Cameron wrote:
>> > I created a sqlite/spatialite db from the spatialite_gui and started to
>> > import a bunch of shapefiles.
>> > Some of the things I set were the CRS to EPSG:3005 "BC Albers" and
>> the_geom
>> > as the name for the geometry field (type is set to auto...)
>> > Then in spatialite_gui I expanded each new table and built a spatial
>> index.
>> > I can also right click each the_geom table and see a valid "Map
>> Preview".
>> > But I can't open or load this .sqlite files into either spatialite_gis
>> or
>> > qgis.
>> > So I think this could be a problem with my actual OS (openSUSE 12.2 x64
>> w/
>> > KDE).
>> > QGIS loads the layers as tables, not vectors.
>> > spatialite_gis thrown an error:
>> > Missing or invalid Spatial Metadata tables:
>> > - spatial_ref_sys
>> > - geometry_columns
>> > Sorry, cowardly quitting ...
>> > But those tables are in the .sqlite db under the "Metadata" portion.
>> > From the layer menu in QGIS, I can't create a layer in a sqlite db. It
>> says
>> > that my layer is invalid and can't be created. Then I can't even see
>> this
>> > sqlite database (that got created successfully, it's just the layer that
>> > failed creation) when navigating from the add vector window. But I can
>> see
>> > it when trying to load from spatialite_gis but that throws the same
>> error.
>> > I noticed in the DB Manager plugin, it says that pyspatialite is missing
>> > and that package isn't available for openSUSE in the open build service,
>> > unless it goes by a different name...
>> to solve the missing pyspatialite:
>> easy_install pyspatialite
>> OR
>> pip install pyspatialite
>> packages for above commands
>> python-setuptools
>> python-pip or python-distrubute
>> Keep in mind that many python packages do not come in the distros but
>> are platform independent and easy to install from the pypi python repo
>> using setup tools or pip.
>> This doesn't solve your original issue. What version of spatialite are
>> you using. QGIS doesn't support the new 4.0 stuff yet...
>> Thanks,
>> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121209/573c03c5/attachment.html>
