[Qgis-user] Qgis-Webclient and startExtent with EPSG900913-Bounds
Salvatore Larosa
lrssvtml at gmail.com
Tue Dec 11 09:15:58 PST 2012
I'm glad it works ! ;-)
Cheers!
2012/12/11 Thomas Baumann <expedio at gmail.com>
> Hi Salvatore,
> thanks for the pull request.
> I adapted my local GetUrlParams.js and now it works perfect.
> thanks again+best wishes,
> Thomas
> 2012/12/11 Salvatore Larosa <lrssvtml at gmail.com>
>> Hi Thomas,
>>> Hello,
>>> I try to set the startExtent for my QGIS-Webclient-Map (a site with
>>> 900913-Global-settings) but encounter Problems with the
>>> EPSG900913-coordinates:
>>> If I try to set the startExtend with
>>> &startExtent=-25913538.399811,-12795102.116832,31935055.700111,12564869.375981
>>> i get following message:
>>> Start-parameter "startExtent" needs to be in OpenLayers.Bounds format:
>>> 'left,bottom,right,top'
>>> Here the structure of my Request:
>>> https://myserver/qgiswebclient/site/qgiswebclient.html?&map=/path_to_my_maps/mapname.qgs&format=image/png&visibleLayers=layer1,layer2&startExtent=-25913538.399811,-12795102.116832,31935055.700111,12564869.375981
>>> AFAIK the problem that existed in earlier versions with negativ values
>>> for the start/maxExtent has been solved but
>>> could it be that the dots of this float-values are still a problem?
>> Yes, the dots are the problem !
>>> Is there a workaround known for this?
>> I just sent a pull request [1] to get rid the problem !
>> Anyway, you can change your local code in order to get it working !
>> Could you give a try and let me know if it works for you ?
>> Regards,
>> -SL
>> [1] - https://github.com/qgis/qgis-web-client/pull/21
>>> best wishes,
>> Thomas
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Salvatore Larosa
>> linkedIn: http://linkedin.com/in/larosasalvatore
>> twitter: @lrssvt
>> skype: s.larosa
>> IRC: lrssvt on freenode
Salvatore Larosa
twitter: @lrssvt
skype: s.larosa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121211/0727cf47/attachment.html>
