[Qgis-user] Qgis-Webclient and startExtent with EPSG900913-Bounds
Salvatore Larosa lrssvtml at gmail.com
Tue Dec 11 08:19:23 PST 2012
Hi Thomas,
2012/12/11 Thomas Baumann <expedio at gmail.com>
> Hello,
> I try to set the startExtent for my QGIS-Webclient-Map (a site with
> 900913-Global-settings) but encounter Problems with the
> EPSG900913-coordinates:
> If I try to set the startExtend with
> &startExtent=-25913538.399811,-12795102.116832,31935055.700111,12564869.375981
> i get following message:
> Start-parameter "startExtent" needs to be in OpenLayers.Bounds format:
> 'left,bottom,right,top'
> Here the structure of my Request:
> https://myserver/qgiswebclient/site/qgiswebclient.html?&map=/path_to_my_maps/mapname.qgs&format=image/png&visibleLayers=layer1,layer2&startExtent=-25913538.399811,-12795102.116832,31935055.700111,12564869.375981
> AFAIK the problem that existed in earlier versions with negativ values for
> the start/maxExtent has been solved but
> could it be that the dots of this float-values are still a problem?
Yes, the dots are the problem !
> Is there a workaround known for this?
I just sent a pull request [1] to get rid the problem !
Anyway, you can change your local code in order to get it working !
Could you give a try and let me know if it works for you ?
Regards,
-SL
[1] - https://github.com/qgis/qgis-web-client/pull/21
> best wishes,
Thomas
> Qgis-user mailing list
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121211/d7b474df/attachment.html>
