[Qgis-user] Sextante tool box problems
Nick Hopton
nhopton at gmail.com
Wed Dec 12 02:33:44 PST 2012
Victor Olaya-3 wrote
> If you go to the SEXTANTE configuration dialog, you will see a "GRASS"
> entry, and there is an option to enable console output logging. Enable
> it, run your GRASS command again...and hopefully you will have
> information about what is happening
Here is the console output log for grass:v.parallel:
GRASS execution console output
Cleaning up temporary files ...
Starting GRASS ...
GRASS_INFO_ERROR(4801,1): MAPSET user not found
GRASS_INFO_END(4801,1)
/home/nick/.qgis//sextante/tempdata/grassdata/temp_location/user: Not a
valid GRASS location
Starting GRASS ...
GRASS_INFO_ERROR(4837,1): MAPSET user not found
GRASS_INFO_END(4837,1)
A few days ago I had the problem described here:
http://osgeo-org.1560.n6.nabble.com/Re-Qgis-user-python-error-td5020446.html
and fixed it as suggested (by changing the first line of file __init__.py).
Whether this has anything to do with the problem I don't know.
Nick.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-tool-box-problems-tp5022297p5022430.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
