[Qgis-user] Sextante tool box problems
Victor Olaya
volayaf at gmail.com
Tue Dec 11 11:54:05 PST 2012
No, you do not need SAGA to run GRASS. You just need it to load the
model that uses SAGA (it is included as an example in SEXTANTE, but
you can ignore it)
If you go to the SEXTANTE configuration dialog, you will see a "GRASS"
entry, and there is an option to enable console output logging. Enable
it, run your GRASS command again...and hopefully you will have
information about what is happening
Regards
Victor
2012/12/11 Nick Hopton <nhopton at gmail.com>:
> Victor Olaya-3 wrote
>> That message is not the problem with the buffer, it is another
>> problem. You have a model that includes a SAGA algorithm (it is an
>> example model), and you probably do not have SAGA installed so it
>> complains and it writes it to the log.
>> You problem description should be in the SEXTANTE log, but in the
>> info branch, tagged as "GRASS console output". That's where you can
>> find why your buffer it is not working
> Thanks for the response Victor. I didn't think I needed SAGA to be installed
> to run GRASS functions from the Sextante tool box. In fact I'm pretty sure
> that until a few days ago GRASS functions did run from the tool box without
> SAGA installed. Anyway, I've installed SAGA, enabled it in the Sextante tool
> box and the GRASS functions still don't work. Which has left me puzzled.
> I don't have anything in the log tagged "Grass console output". I've just
> tried using grass.v.parallel which failed with the same message as before.
> The only thing written to the log file was under "Algorithm":
> sextante.runalg("grass:v.parallel","/home/nick/beenham/walk_maps/long.shp",20,20,0,2,1,False,False,"458542.246135,459826.641395,168788.919831,170532.062032",0,None)
> Nick.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-tool-box-problems-tp5022297p5022322.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
