[Qgis-user] OpenLayer scales differently from other in QGIS Print Composer
Alex Druk
alex.druk at gmail.com
Mon Dec 17 08:41:47 PST 2012
I am running QGIS 1.8.0-Lisboa on Mac 10.8.2
Yes, my problem looks like the bug
http://hub.qgis.org/issues/**6653<http://hub.qgis.org/issues/6653>
On Mon, Dec 17, 2012 at 4:20 PM, Alex Druk <alex.druk at gmail.com> wrote:
> Hi everyone,
> Sorry for primitive question from novice!
> I map different plant species distribution and use Google Physical layer
> (via OpenLayers plugin) as base map.
> The problem is that in Print Composer even when all layers visually look
> fine, Physical layer scales differently from all others on paper or in
> image and all my species somehow occur in the middle of Ohio or somewhere
> else. I tried OCM Landscape layer with same results.
> What I do wrong?
> I would appreciate your advice.
> Thank you.
> Alex Druk
> (775) 237-8550 Google voice
Thank you.
Alex Druk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121217/fd9fe632/attachment.html>
