[Qgis-user] OpenLayer scales differently from other in QGIS Print Composer
Albin Blaschka albin.blaschka at standortsanalyse.net
Mon Dec 17 07:37:15 PST 2012
Hello!
The layers you mentioned (Google, those derived from OSM) have only
"distinct" scales (and their very own projection) - if your map is
somewhere between two of those scale-levels it could be possible that
your layers do not align properly - at least it was like that here with
a project of mine and OCM Landscape...
So, choose a different scale and the layers should align properly...
HTH,
Albin
Am 17.12.2012 16:20, schrieb Alex Druk:
> Hi everyone,
> Sorry for primitive question from novice!
> I map different plant species distribution and use Google Physical layer
> (via OpenLayers plugin) as base map.
> The problem is that in Print Composer even when all layers visually look
> fine, Physical layer scales differently from all others on paper or in
> image and all my species somehow occur in the middle of Ohio or
> somewhere else. I tried OCM Landscape layer with same results.
> What I do wrong?
> I would appreciate your advice.
> Thank you.
> Alex Druk
> alex.druk at gmail.com <mailto:alex.druk at gmail.com>
> (775) 237-8550 Google voice
> Qgis-user mailing list
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info * www.thinkanimal.info *
| - It's hard to live in the mountains, hard but not hopeless!
