[Qgis-user] OpenLayer scales differently from other in QGIS Print Composer
Samy Mezani
samy.mezani at wanadoo.fr
Mon Dec 17 07:33:16 PST 2012
le 17/12/2012 16:20, Alex Druk a écrit:
> I map different plant species distribution and use Google Physical layer
> (via OpenLayers plugin) as base map.
> The problem is that in Print Composer even when all layers visually look
> fine, Physical layer scales differently from all others on paper or in
> image and all my species somehow occur in the middle of Ohio or
> somewhere else. I tried OCM Landscape layer with same results.
Are you running a GNU/Linux distribution ?
There is a open bug here : http://hub.qgis.org/issues/6653
Samy
