[Qgis-user] Opening QGIS more than one time on OSX
William Kyngesburye
woklist at kyngchaos.com
Tue Dec 18 06:47:11 PST 2012
Opening an app more than once is not normal, and not the correct way to open multiple windows/projects for an app on OS X. The app must be designed to open multiple projects if that behavior is desired.
Different application document model on OS X. I'd rather not promote hacks like this, it might confuse OS X users (ie. you get an icon in the Dock for each app instance, not normal).
On Dec 18, 2012, at 2:18 AM, Andreas Neumann wrote:
> Hi,
> On Linux or Windows you can easily open QGIS several times, e.g. to see more than one project side by side. Unfortunately, on OSX, this is not so easy.
> I came across http://gis.stackexchange.com/questions/25275/how-to-open-two-projects-at-once-in-one-qgis-window - suggesting to start it again from the command line with "open -n /Applications/QGIS.app/" - however, since many OSX users do not know about the command line - is there a more user friendly trick to open QGIS a second or third time?
> Thanks,
> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
