[Qgis-user] Opening QGIS more than one time on OSX
Andreas Neumann
a.neumann at carto.net
Tue Dec 18 07:18:06 PST 2012
Hi all,
Thank you all for your input. Seems to be that the mid-term goal should
be to allow the opening of several projects while in the short-term,
people can use one of the workarounds discussed here.
Thanks,
Andreas
On Tue, 18 Dec 2012 08:47:11 -0600, William Kyngesburye wrote:
> Opening an app more than once is not normal, and not the correct way
> to open multiple windows/projects for an app on OS X. The app must
> be
> designed to open multiple projects if that behavior is desired.
> Different application document model on OS X. I'd rather not promote
> hacks like this, it might confuse OS X users (ie. you get an icon in
> the Dock for each app instance, not normal).
> On Dec 18, 2012, at 2:18 AM, Andreas Neumann wrote:
>> Hi,
>> On Linux or Windows you can easily open QGIS several times, e.g. to
>> see more than one project side by side. Unfortunately, on OSX, this is
>> not so easy.
>> I came across
>> http://gis.stackexchange.com/questions/25275/how-to-open-two-projects-at-once-in-one-qgis-window
>> - suggesting to start it again from the command line with "open -n
>> /Applications/QGIS.app/" - however, since many OSX users do not know
>> about the command line - is there a more user friendly trick to open
>> QGIS a second or third time?
>> Thanks,
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is
> over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people
> of the allied nations devoted an entire year exclusively to hating
> the
> ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
Andreas Neumann
Switzerland
