[Qgis-user] How to transform a selected multipart feature into singlepart features during a edit session in QGIS? [SOLVED]
Alexandre Neto senhor.neto at gmail.com
Mon Dec 31 09:20:54 PST 2012
Inspired by this question &
answer<http://gis.stackexchange.com/questions/9261/switch-line-direction-in-qgis>
as
an example of how "easily" can one make its own solutions when using Open
Source, I have tried to create my own code to selectively "explode"
multipart features during an editing session.
I have explored the QGIS 1.8 API <http://qgis.org/api/1.8/> for the first
time, and came out with this piece of code that seams to do the job:
layer = qgis.utils.iface.mapCanvas().currentLayer()
remove_list = []
for feature in layer.selectedFeatures():
    geom = feature.geometry()
    # check if feature geometry is multipart
    if geom.isMultipart():
        remove_list.append(feature.id())
        new_features = []
        temp_feature = QgsFeature(feature)
        # create a new feature using the geometry of each part
        for part in geom.asGeometryCollection ():
            temp_feature.setGeometry(part)
            new_features.append(QgsFeature(temp_feature))
        # add new features to layer
        layer.addFeatures(new_features, False)
# remove the original (multipart) features from layerif len(remove_list) > 0:
    for id in remove_list:
        layer.deleteFeature (id)
I'm not an experienced programmer, so the code might not be the most
efficient one.
Next steep will be to make a plugin out of it... Or at least, try to!
Alexandre Neto
On Thu, Dec 27, 2012 at 12:36 PM, Alexandre Neto <senhor.neto at gmail.com>wrote:
> There are several questions and respective answers for how to make a
> multipart features Layer into a singlepart features one using QGIS:
>    - How to break a single polygon into multiple polys?<http://gis.stackexchange.com/questions/27825/how-to-break-a-single-polygon-into-multiple-polys>
>    - How to split non-contiguous feature in QGIS?<http://gis.stackexchange.com/questions/23377/how-to-split-non-contiguous-feature-in-qgis>
> But all the solutions I saw, creates a entirely new layer and would
> transform ALL the multipart geometries into single ones.
> So the questions is, how could one, during an edit session, *selectively* transform
> a multipart feature into a singlepart feature, without the need to create a
> new layer?
> I saw a ticket <http://trac.osgeo.org/qgis/ticket/3278> for this but it
> seems to have been misunderstood.
> It would be the opposite to the "merge selected features" tool, and
> similar to explode<http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Merging_and_separating_features> in
> ArcGIS.
> Is there any plugin doing this? How could this be done using the python
> console?
> Alexandre Neto
> PS: I have posted the same question<http://gis.stackexchange.com/questions/44799/how-to-transform-a-selected-multipart-feature-into-singlepart-features-during-a>in
> gis.stackexchange.com In case anyone wants to answer there.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121231/06910a11/attachment.html>
