[Qgis-user] How to transform a selected multipart feature into singlepart features during a edit session in QGIS? [SOLVED]
vinayan
vinayan123 at gmail.com
Mon Dec 31 18:59:04 PST 2012
that is really cool! I have also felt(coming from ArcGis background :-)
) that this should be somewhere in the advanced editing
toolbar..although there is a delete part tool in Qgis, exploding
selected features this way are much easier for users..
On Monday 31 December 2012 10:50 PM, Alexandre Neto wrote:
> Inspired by this question & answer
> <http://gis.stackexchange.com/questions/9261/switch-line-direction-in-qgis> as
> an example of how "easily" can one make its own solutions when using
> Open Source, I have tried to create my own code to selectively
> "explode" multipart features during an editing session.
> I have explored the QGIS 1.8 API <http://qgis.org/api/1.8/> for the
> first time, and came out with this piece of code that seams to do the job:
> |layer= qgis.utils.iface.mapCanvas().currentLayer()
> remove_list= []
> for featurein layer.selectedFeatures():
> geom= feature.geometry()
> # check if feature geometry is multipart
> if geom.isMultipart():
> remove_list.append(feature.id())
> new_features= []
> temp_feature= QgsFeature(feature)
> # create a new feature using the geometry of each part
> for partin geom.asGeometryCollection():
> temp_feature.setGeometry(part)
> new_features.append(QgsFeature(temp_feature))
> # add new features to layer
> layer.addFeatures(new_features, False)
> # remove the original (multipart) features from layer
> if len(remove_list) > 0:
> for idin remove_list:
> layer.deleteFeature(id) |
> I'm not an experienced programmer, so the code might not be the most
> efficient one.
> Next steep will be to make a plugin out of it... Or at least, try to!
> Alexandre Neto
> On Thu, Dec 27, 2012 at 12:36 PM, Alexandre Neto
> <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>> wrote:
> There are several questions and respective answers for how to make
> a multipart features Layer into a singlepart features one using QGIS:
> * How to break a single polygon into multiple polys?
> <http://gis.stackexchange.com/questions/27825/how-to-break-a-single-polygon-into-multiple-polys>
> * How to split non-contiguous feature in QGIS?
> <http://gis.stackexchange.com/questions/23377/how-to-split-non-contiguous-feature-in-qgis>
> But all the solutions I saw, creates a entirely new layer and
> would transform ALL the multipart geometries into single ones.
> So the questions is, how could one, during an edit session,
> *selectively* transform a multipart feature into a singlepart
> feature, without the need to create a new layer?
> I saw a ticket <http://trac.osgeo.org/qgis/ticket/3278>for this
> but it seems to have been misunderstood.
> It would be the opposite to the "merge selected features" tool,
> and similar to explode
> <http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Merging_and_separating_features> in
> ArcGIS.
> Is there any plugin doing this? How could this be done using the
> python console?
> Alexandre Neto
> PS: I have posted the same question
> <http://gis.stackexchange.com/questions/44799/how-to-transform-a-selected-multipart-feature-into-singlepart-features-during-a>in
> gis.stackexchange.com <http://gis.stackexchange.com> In case
> anyone wants to answer there.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130101/ecbddc47/attachment.html>
