[Qgis-user] [qgisserver] relatif path in qgs and raster issue
Yves Jacolin
yjacolin at free.fr
Wed Feb 1 06:36:18 PST 2012
Hello,
Le mercredi 01 février 2012 15:27:17, Andreas Neumann a écrit :
> Hi,
> relative paths in QGIS server should work fine - at least it does on my
> system. Did you manually check in the .qgs file if the paths are really
> stored as relative?
Yes they are!
> On my system (QGIS trunk, 2-3 days old) self-compiled on Ubuntu 10.04
> LTS it works fine.
> I would first check the source of the .qgs file if the paths are really
> stored as relative and if the files are really available on the server -
> also double check permissions if the wwwrun can access the data.
The datasource are relative to qgs file not qgis_server.fcgi file. Is it
correct? My qgis file are in one location (my home in the server with the data)
and fcgi script is in /usr/lib/cgi-bin/ dir.
Thanks Andreas
Y.
> On Wed, 1 Feb 2012 14:46:34 +0100, Yves Jacolin wrote:
> > Hello,
> > I am testing qgis-server with libqgis-1.7.3 and qgis-1.7.1 for the
> > deskop
> > side.
> > I create a qgis project with qgis-1.7.1 all is fine. I have two
> > layers : raster
> > in netCDF and another in shapefile. I put this qgis project file to
> > the server
> > and test my new WMS service. The raster layer is rotated and reversed
> > (see
> > [1]).
> > If I upgrade qgis on my desktop to 1.7.3 I get the same issue.
> > Is it something known? I don't have the possibility to test the 1.7.4
> > release
> > as the ubuntu package is not ready. I will try to investigate tonight
> > as I
> > have a trunk install for QGIS at home.
> > Last question: relatif path could not be used in qgis project file
> > for qgis-
> > server. That seems curious to me as the path is not always the same
> > between
> > the deskop system and the server system. Anyway do you plan to change
> > this? Do
> > I need to fill a ticket?
> > Thanks,
> > Y.
> > [1] http://imageshack.us/photo/my-images/15/qgisserver.png/
Yves Jacolin
http://yjacolin.gloobe.org
