[Qgis-user] Raster banding in print composer
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Sat Feb 11 02:12:56 PST 2012
Hi Matt
Is the raster image transparent? It is a known issue that there is
banding with transparent rasters (because the raster is printed in
several pieces with a small overlap). There is work underway in the
raster_resampling branch to draw the pieces without overlap (in fact,
the credits go to Radim here since it is only possible to avoid the
overlaps after his raster provider redesign).
If the raster is fully opaque, it might be a different issue.
Regards,
Marco
On 11.02.2012 08:26, Matt Conway wrote:
> Hi,
> I'm using a GeoTIFF with a color map, and when I use print composer to
> export I get banding across the image if I set the quality above
> 100dpi. Any thoughts?
> I'm using QGIS 1.9.90 nightly (updated about 4 hours ago) on Ubuntu 11.10.
> Image: http://www.flickr.com/photos/mattwigway/6855286347/
> Thanks,
> Matt
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole - Linux& Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120211/0b482854/attachment.html>
