[Qgis-user] Raster banding in print composer
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Sat Feb 11 22:05:09 PST 2012
Hi Matt
It is ready to use. There might be some smaller issues to fix in the
branch. However if you just need a background map, it should be no problem.
The code is available on github, repository
git://github.com/mhugent/Quantum-GIS.git
Regards,
Marco
On 11.02.2012 18:33, Matt Conway wrote:
> Yes, it's a transparent raster. Is the work in raster_resampling ready
> to use, or need I try something else?
> Thanks,
> Matt
> On 02/11/2012 02:12 AM, Marco Hugentobler wrote:
>> Hi Matt
>> Is the raster image transparent? It is a known issue that there is
>> banding with transparent rasters (because the raster is printed in
>> several pieces with a small overlap). There is work underway in the
>> raster_resampling branch to draw the pieces without overlap (in fact,
>> the credits go to Radim here since it is only possible to avoid the
>> overlaps after his raster provider redesign).
>> If the raster is fully opaque, it might be a different issue.
>> Regards,
>> Marco
>> On 11.02.2012 08:26, Matt Conway wrote:
>>> Hi,
>>> I'm using a GeoTIFF with a color map, and when I use print composer
>>> to export I get banding across the image if I set the quality above
>>> 100dpi. Any thoughts?
>>> I'm using QGIS 1.9.90 nightly (updated about 4 hours ago) on Ubuntu
>>> 11.10.
>>> Image: http://www.flickr.com/photos/mattwigway/6855286347/
>>> Thanks,
>>> Matt
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Dr. Marco Hugentobler
>> Sourcepole - Linux& Open Source Solutions
>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120212/3b46bb9c/attachment.html>
