[Qgis-user] problems Open Layer Plugin
    Cao Minh Tu
    caominhtuvn at gmail.com
    Fri Feb 24 17:12:57 PST 2012
Hi Dario,
As Giovanni said, it's because those maps just available at some fixed
scale.
At times when I see a shift in my map like you described, it's normally
because I used the "Zoom in" tool and zoom into an arbitrary region.
To fix it, I hand-enter the scale at the bottom right box with one of
these values:
1:564
1:1127
1:2255
1:4510
1:9020
1:18040
1:36080
1:72160
1:144320
1:288640
1:577280
1:1154560
1:2309120
1:4618240
1:9236480
1:18472960
1:36945920
1:73891840
1:147783680
1:295567360
(these values I got when I first add the Open Layer into Qgis and scroll
the mouse wheel)
Or maybe you can use values from this page:
/http://msdn.microsoft.com/en-us/library/bb259689.aspx/
*[help needed: can any one on the list please explain the values from
which source is more precise?]*
After entering one of the above values, you should only zoom in and out
of the map by scrolling the mouse wheel.
Best regards!
-- Cao Minh Tu --
/*@Giovanni: */Sorry, I made a mistake by replying the previous email
just to you. Please remove it. Thanks.
Ngày 24/02/2012 07:19 PM, Giovanni Manghi viết:
> Hi Dario,
> when using the OL plugin your project must be in Google Mercator with
> OTFR enabled. Sometimes there are "shifts" but if you pan a little the
> canvas everything goes in its place (it is because the maps from Google
> et al are not available at every scale).
> About the error try remove openlayers overview plugin (now integrated
> into Openlayers).
> cheers
> -- Giovanni --
> On Fri, 2012-02-24 at 04:11 -0800, Dario wrote:
>> Hello Friends,
>> When using the plugin with the option Openlayer Google Earth, I have
>> been a big shift between the point indicated on my map and point shown
>> in Google Earth.
>> My map is in UTM projection, SAD 69, zone 24S, EPSG = 29194
>> (I'm using on-the-fly)
>> When trying to add image of GE states the following:
>> The OpenLayers plugin version is 0.71, need be 0:42 version!
>> I have to revert to the old version? How to do it?
>> Dario
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120225/e505f49b/attachment.html>
