[Qgis-user] Re: GPX and GPX_USE_EXTENSIONS
Luca Casagrande
luca.casagrande at gmail.com
Mon Feb 27 07:52:38 PST 2012
Yes, I used the Save As option.
Do you know any other way to add waypoints to an existing GPX file?
Luca
Marco Lechner - FOSSGIS e.V. wrote
> Hi Luca,
> "converting" a Shape to GPX uses OGR-tools while the GPS-Plugin is a
> very long existing plugin reading/writing GPS natively, I guess.
> Marco
> Am 27.02.2012 16:40, schrieb Luca Casagrande:
>> Hello everybody,
>> I converted a line ShapeFile into GPX using the GPX_USE_EXTENSIONS option
>> and the attributes are correctly exported.
>> Now, if I try to add some waypoints to that file using the GPS Plugin,
>> the
>> attributes disappear.
>> Anyone with the same problem?
>> Thanks
>> Luca
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515205.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> Qgis-user at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515243.html
