[Qgis-user] Re: GPX and GPX_USE_EXTENSIONS
Marco Lechner - FOSSGIS e.V.
marco.lechner at fossgis.de
Mon Feb 27 08:03:22 PST 2012
Adding it to the source shapefile and then converting?
Am 27.02.2012 16:52, schrieb Luca Casagrande:
> Yes, I used the Save As option.
> Do you know any other way to add waypoints to an existing GPX file?
> Luca
> Marco Lechner - FOSSGIS e.V. wrote
>> Hi Luca,
>> "converting" a Shape to GPX uses OGR-tools while the GPS-Plugin is a
>> very long existing plugin reading/writing GPS natively, I guess.
>> Marco
>> Am 27.02.2012 16:40, schrieb Luca Casagrande:
>>> Hello everybody,
>>> I converted a line ShapeFile into GPX using the GPX_USE_EXTENSIONS option
>>> and the attributes are correctly exported.
>>> Now, if I try to add some waypoints to that file using the GPS Plugin,
>>> the
>>> attributes disappear.
>>> Anyone with the same problem?
>>> Thanks
>>> Luca
>>> View this message in context:
>>> http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515205.html
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>> Qgis-user mailing list
>>> Qgis-user at .osgeo
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Qgis-user at .osgeo
> View this message in context: http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515243.html
