[Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
Angelos Tzotsos gcpp.kalxas at gmail.com
Mon Feb 27 09:47:26 PST 2012
QGIS 1.7.4 works fine in my machines
You should add this repository in your system:
http://download.opensuse.org/repositories/devel:/languages:/python/openSUSE_12.1/
update and try installing qgis again
Regards,
Angelos
On 02/27/2012 06:24 PM, Donovan Cameron wrote:
> I noticed my error when QGIS upgraded to 1.7.3 as well, but never got
> around to reporting it, then 1.7.4 came out soon afterwards. It opened
> and ran fine in v 1.7.2
> I will check my python version when I get home tonight and see if that
> could be it if not, I may rollback to 1.7.2.
> I'll follow your forum thread for updates as well.
> Donovan
> On Mon, Feb 27, 2012 at 8:24 AM, Kerick Leite
> <kerick.quimica at gmail.com <mailto:kerick.quimica at gmail.com>> wrote:
>     I had a problem with the installation of QGIS 1.7.3 in the same
>     version of OpenSUSE as yours. The problem was caused by a missing
>     dependency also related to python. I've posted the problem in the
>     forum, but so far there wasn't a reply:
>     http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6
>     <http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6>
>     Regards,
>     Kerick
>         Message: 6
>         Date: Sun, 26 Feb 2012 16:38:10 -0700
>         From: Donovan Cameron <sault.don at gmail.com
>         <mailto:sault.don at gmail.com>>
>         Subject: [Qgis-user] QGIS 1.7.4 doesn't run in OpenSUSE 12.1
>         To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>         Message-ID:
>         <CAJo0jfPr+K5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw at mail.gmail.com
>         <mailto:CAJo0jfPr%2BK5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw at mail.gmail.com>>
>         Content-Type: text/plain; charset="iso-8859-1"
>         When I try to run qgis from the terminal, the splash shows,
>         but as soon as
>         it gets to the part "Starting Python" the splash simply closes.
>         The output from the terminal is:
>         *qgis: siplib.c:10938: sipEnumType_alloc: Assertion
>         `(((currentType)->td_flags & 0x0007) == 0x0003)' failed.*
>         *Aborted*
>         I downloaded and installed QGIS from the "geo" repository (
>         http://download.opensuse.org/repositories/Application:/Geo/openSUSE_12.1/)
>         QGIS: 1.7.4-Wroclaw
>         OS: OpenSUSE 12.1 with KDE 4.8
>         Kernel: 3.1.9-1.4-desktop
>         Regards,
>         Donovan
>         -------------- next part --------------
>         An HTML attachment was scrubbed...
>         URL:
>         http://lists.osgeo.org/pipermail/qgis-user/attachments/20120226/8bedc4f5/attachment-0001.html
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120227/c451c229/attachment.html>
