[Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
pcreso at pcreso.com pcreso at pcreso.com
Mon Feb 27 13:03:01 PST 2012
Hi Angelos,
I just installed QGIS 1.74 (from 1.73 which worked fine) on OpenSuse 12.1 64bit.
It is now broken with a startup error message as below.
My libpython was 2.7 from the standard repository. This had the same version as the python repo you suggested.
QGIS is running, but with no python support, my system is fully updated as far as I can tell.
Any advice/fixes appreciated...
Thanks,
  Brent
Error msg below
_____________________________________________________________
p, li { white-space: pre-wrap; }
Couldn't load PyQGIS.
Python support will be disabled.
  File "", line 1, in
ImportError: /usr/share/qgis/python/qgis/core.so: undefined symbol: _ZNK7QObject17senderSignalIndexEv
Python version:
2.7.2 (default, Aug 19 2011, 20:41:43) [GCC]
QGIS version:
1.7.4-Wroclaw 'Wroclaw', exported
________________________________________________________________
--- On Tue, 2/28/12, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
Subject: Re: [Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
To: qgis-user at lists.osgeo.org
Date: Tuesday, February 28, 2012, 6:47 AM
    QGIS 1.7.4 works fine in my machines
    You should add this repository in your system:
http://download.opensuse.org/repositories/devel:/languages:/python/openSUSE_12.1/
    update and try installing qgis again
    Regards,
    Angelos
    On 02/27/2012 06:24 PM, Donovan Cameron wrote:
    I noticed my error when QGIS upgraded to 1.7.3 as
      well, but never got around to reporting it, then 1.7.4 came out
      soon afterwards. It opened and ran fine in v 1.7.2
      I will check my python version when I get home tonight and
        see if that could be it if not, I may rollback to 1.7.2.
      I'll follow your forum thread for updates as well.
      Donovan
        On Mon, Feb 27, 2012 at 8:24 AM, Kerick
          Leite <kerick.quimica at gmail.com>
          wrote:
          I had a
            problem with the installation of QGIS 1.7.3 in the same
            version of OpenSUSE as yours. The problem was caused by a
            missing dependency also related to python. I've posted the
            problem in the forum, but so far there wasn't a reply:
            http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6
            Regards,
            Kerick
                Message: 6
                Date: Sun, 26 Feb 2012 16:38:10 -0700
                Subject: [Qgis-user] QGIS 1.7.4 doesn't run in OpenSUSE
                12.1
                Message-ID:
                       <CAJo0jfPr+K5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw at mail.gmail.com>
                Content-Type: text/plain; charset="iso-8859-1"
                  When I try to run qgis from the terminal, the splash
                  shows, but as soon as
                  it gets to the part "Starting Python" the splash
                  simply closes.
                  The output from the terminal is:
                *qgis: siplib.c:10938: sipEnumType_alloc: Assertion
                `(((currentType)->td_flags & 0x0007) == 0x0003)'
                failed.*
                *Aborted*
                  I downloaded and installed QGIS from the "geo"
                  repository (
                  http://download.opensuse.org/repositories/Application:/Geo/openSUSE_12.1/)
                  QGIS: 1.7.4-Wroclaw
                  OS: OpenSUSE 12.1 with KDE 4.8
                  Kernel: 3.1.9-1.4-desktop
                  Regards,
                  Donovan
                URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120226/8bedc4f5/attachment-0001.html
            Qgis-user mailing list
            Qgis-user at lists.osgeo.org
            http://lists.osgeo.org/mailman/listinfo/qgis-user
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120227/83021cbd/attachment.html>
