[Qgis-user] Questions QGIS webclient
bernhard.stroebl at jena.de
Tue Feb 28 01:16:08 PST 2012
Hi Andreas,
the server is currently not available from outside so here is the
wsgi-scripts' output:
http://10.144.9.51/wsgi/search.wsgi?searchtables=kartenportal.suche_alles&query=Am%20alten%20Gaswerk&cb=bla
bla({"results": [{"searchtable": null, "displaytext": "Strassen",
"bbox": null}, {"searchtable": "kartenportal.suche_alles",
"displaytext": "Am alten Gaswerk (Strasse)", "bbox":
[(4471973.5,5645101.5,4472185.5,5645205.5)]}, {"searchtable": null,
"displaytext": "Adressen", "bbox": null}, {"searchtable":
"kartenportal.suche_alles", "displaytext": "Am alten Gaswerk 1
(Adresse)", "bbox": [(4472041,5645209,4472041,5645209)]},
{"searchtable": "kartenportal.suche_alles", "displaytext": "Am alten
Gaswerk 2 (Adresse)", "bbox": [(4472071.5,5645134.5,4472072,5645135)]},
Gaswerk 4 (Adresse)", "bbox": [(4472106,5645099,4472106,5645099)]},
Gaswerk 7 (Adresse)", "bbox": [(4472169,5645181,4472169,5645181)]},
Gaswerk 7a (Adresse)", "bbox": [(4472182.5,5645202,4472183,5645202.5)]},
Gaswerk 9 (Adresse)", "bbox": [(4472187,5645130.5,4472187.5,5645131)]}]})
http://10.144.9.51/wsgi/getSearchGeom.wsgi?_dc=1330359714648&searchtable=kartenportal.suche_alles&displaytext=Am%20alten%20Gaswerk%20(Strasse)
MULTILINESTRING((4471973.6667815 5645205.155335,4472011.32780392
5645187.04378521,4472168.93332659 5645110.52723776,4472185.36362809
5645101.54646928))
I am using EPSG:31468 (QGIS project's setting, QGIS project's WMS
coordinate system, data srid)
GlobalOption.js - snippet:
//EPSG projection code
var epsgcode = 31468;
// OpenLayers global options
// see
http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Map-js.html
var MapOptions = {
projection: new OpenLayers.Projection("EPSG:"+epsgcode),
units: "m",
maxScale:50,
minScale:150000,
fractionalZoom: true,
transitionEffect:"resize",
controls: []
tooltip works now with field named "tooltip"
Bernhard
Am 27.02.2012 22:06, schrieb Andreas Neumann:
> Hi Bernhard,
> On 02/27/2012 05:22 PM, bernhard.stroebl at jena.de wrote:
>> Dear all,
>> I am fiddling around with QGIS server and webclient and I do like both
>> of them. Thank you for this software!
>> Whereas QGIS server's configuration is pretty straightforward QGIS
>> webclient is a higher hurdle.
>> Here are some questions (more to follow, I am sure :):
>> 1) searchComboBox: I configured two search relations (views): streets
>> MULTILINESTRING and addresses POINT in my database and they are searched
>> ok BUT the map does not zoom in at the feature chosen in the comboBox
>> although the geometry is highlighted on the map
> It really should zoom to the feature. Maybe it is an issue of map scale
> or units? What units and scales are you using?
> Do you have the search somewhere available to test or can you share a
> snippet from the search result?
> Here is a valid request on my server and the corresponding result:
> http://webgis.uster.ch/wsgi/search.wsgi?query=&searchtables=&query=Hasenb%C3%BCe&cb=stcCallback1003
> stcCallback1003({"results": [
> {"searchtable": null, "displaytext": "Flurnamen", "bbox":
> null},{"searchtable": "av_user.suchtabelle", "displaytext":
> "Hasenb\u00fcel (Flurname, Uster)", "bbox":
> [696321.5,245623.015625,696878.875,246087.875]},
> {"searchtable": "av_user.suchtabelle", "displaytext": "Hinterer
> [696621.375,245924.890625,697073.5,246226.640625]},
> {"searchtable": null, "displaytext": "Strassen", "bbox": null},
> Hasenb\u00fcelweg (Strasse, Uster)", "bbox":
> [696699.75,245958.046875,697006.375,246224.640625]},
> {"searchtable": "av_user.suchtabelle", "displaytext": "Vorderer
> [696454.25,245665.265625,696863.6875,246017.96875]}
>> 2) MapTips: the map tip always shows the layer's name no matter which
>> field I defined in my layer properties in the project. Or is the
>> webclient's map tip configured elsewhere?
> Currently it is hardwired to a column named "tooltip". You need to
> create an attribute or column in your table or view named "tooltip".
> Currently there is no way to know which column is set for the maptip.
> Later we will take the column name from the QGIS configuration as soon
> as QGIS server supports that. The current GetCapabilities request does
> not tell us which column is set for map tips. I think this will be
> available later this spring as we also want to have the ability to
> dynamically set map tips for QGIS client.
> Hope this helps,
> Andreas
> Qgis-user mailing list
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
Bernhard Ströbl
Anwendungsbetreuer GIS
Kommunale Immobilien Jena
Am Anger 26
07743 Jena
Tel.: 03641 49- 5190
E-Mail: bernhard.stroebl at jena.de
Internet: www.kij.de
Eigenbetrieb der Stadt Jena
Werkleiter: Thomas Dirkes
