[Qgis-user] RE: Qgis-user] openlayers layers without properties is it possible to alter brightness/contrast
M.E.Dodd
m.e.dodd at open.ac.uk
Tue Feb 28 01:42:10 PST 2012
Thanks for the suggestion, I tried putting the opacity value here:
var osm = new OpenLayers.Layer.OSM(
"OpenStreetMap",
"http://tile.openstreetmap.org/${z}/${x}/${y}.png",opacity:0.5
In the openstreetmaps .html but that made the map vanish altogether so I removed the 'opacity:0.5' and osm map reappeared again. Do I need to stick it somewhere else in the .html file?
-----Original Message-----
From: Richard Duivenvoorde [mailto:rdmailings at duif.net]
Sent: 28 February 2012 09:19
To: M.E.Dodd
Cc: 'Alister Hood'; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] RE: Qgis-user] openlayers layers without properties is it possible to alter brightness/contrast
On 02/28/2012 09:46 AM, M.E.Dodd wrote:
> Have downloaded the .qml files but now not sure how to proceed. I have osm via openlayers but that does not have properties so ...
If you are using OpenStreetmap as a background via the OpenLayers Plugin, then you are stuck with the coloring of the layer provider (either OSM, Yahoo or Google).
But what you can do is set the opacity of the OpenLayers Layer in the html that is used by the plugin. This plugin is actually a html-page showing up in QGIS.
To change the opacity of the layer, go to the plugin directory:
~/.qgis/python/plugins/openlayers
(or in windows it is in your Documents and Settings....)
there is a directory 'html' in which some html files reside which are used by the OpenLayers plugin.
Currently my OSM layers seems broken, but if I open the file google_streets.html in a text editor, and find the lines:
var gmap = new OpenLayers.Layer.Google(
"Google Streets", // the default
{ numZoomLevels: 20}
and add opacity to the layer props by making it this:
{ numZoomLevels: 20, opacity:0.5 }
Now when you use the OpenLayers plugin, you will have a much softer background...
You can change opacity to any number between 0 and 1 See also: http://openlayers.org/dev/examples/layer-opacity.html
Hope this is usefull,
Regards,
The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302).
