[Qgis-user] RE: Qgis-user] openlayers layers without properties is it possible to alter brightness/contrast
Richard Duivenvoorde
rdmailings at duif.net
Tue Feb 28 02:23:41 PST 2012
On 02/28/2012 10:42 AM, M.E.Dodd wrote:
> Thanks for the suggestion, I tried putting the opacity value here:
> var osm = new OpenLayers.Layer.OSM(
> "OpenStreetMap",
> "http://tile.openstreetmap.org/${z}/${x}/${y}.png",opacity:0.5
> In the openstreetmaps .html but that made the map vanish altogether so I removed the 'opacity:0.5' and osm map reappeared again. Do I need to stick it somewhere else in the .html file?
It is a property which you should add in the 'options'-object (I'm
talking OpenLayers lingua now, have a look at OpenLayers.org):
So, change this in osm.html:
"OpenStreetMap",
eventListeners: {
"loadstart": layerLoadStart,
"loadend": layerLoadEnd
Into this:
"OpenStreetMap",
eventListeners: {
,opacity:0.5
This should work :-)
Regards,
