[Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
Sascha Eichenauer
grabenrandstoerung at web.de
Tue Feb 28 03:59:45 PST 2012
On 02/28/2012 04:43 AM, pcreso at pcreso.com wrote:
Dear list,
we seem to be in a Python thing now. Afaik, Python should only matter,
when it comes to plugins - startup should not be a python related issue.
Donovan, did you enable any plugins? The most easy way to sort out that
problem would be to mv /home/donovan/.qgis to /yourpalate. With an
empty .qgis folder I'd expect you to be able to start QGIS, cause no
fancy plugins will be loaded. Should it refuse to start you might have a
qt compatibility issue, which is what I expect.
good luck!
> Hmmm....
> I'm running 1.73 without problems on 12.1. I have libpython2.7 installed, from the main OpenSuse repository. QGIS seems happy with this, although I have not tried to upgrade to 1.74 yet.
> Have you tried seaching for libpython with the Yast software manager & seeing what is available for your system?
> Or you can use the OpenSuse one-click installer at:
> http://software.opensuse.org/ymp/openSUSE:12.1:Update/standard/libpython2_7-1_0.ymp?base=openSUSE%3A12.1&query=libpython
> HTH,
> Brent Wood
> --- On Tue, 2/28/12, Donovan Cameron <sault.don at gmail.com> wrote:
> From: Donovan Cameron <sault.don at gmail.com>
> Subject: Re: [Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
> To: qgis-user at lists.osgeo.org
> Date: Tuesday, February 28, 2012, 5:24 AM
> I noticed my error when QGIS upgraded to 1.7.3 as well, but never got around to reporting it, then 1.7.4 came out soon afterwards. It opened and ran fine in v 1.7.2
> I will check my python version when I get home tonight and see if that could be it if not, I may rollback to 1.7.2.
> I'll follow your forum thread for updates as well.
> Donovan
> On Mon, Feb 27, 2012 at 8:24 AM, Kerick Leite <kerick.quimica at gmail.com> wrote:
> I had a problem with the installation of QGIS 1.7.3 in the same version of OpenSUSE as yours. The problem was caused by a missing dependency also related to python. I've posted the problem in the forum, but so far there wasn't a reply:
> http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6
> Regards,
> Kerick
> Message: 6
> Date: Sun, 26 Feb 2012 16:38:10 -0700
> Subject: [Qgis-user] QGIS 1.7.4 doesn't run in OpenSUSE 12.1
> Message-ID:
> <CAJo0jfPr+K5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> When I try to run qgis from the terminal, the splash shows, but as soon as
> it gets to the part "Starting Python" the splash simply closes.
> The output from the terminal is:
> *qgis: siplib.c:10938: sipEnumType_alloc: Assertion
> `(((currentType)->td_flags & 0x0007) == 0x0003)' failed.*
> *Aborted*
> I downloaded and installed QGIS from the "geo" repository (
> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_12.1/)
> QGIS: 1.7.4-Wroclaw
> OS: OpenSUSE 12.1 with KDE 4.8
> Kernel: 3.1.9-1.4-desktop
> Regards,
> Donovan
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120226/8bedc4f5/attachment-0001.html
> Qgis-user mailing list
> -----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120228/d2b0035d/attachment.html>
