[Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
pcreso at pcreso.com pcreso at pcreso.com
Mon Feb 27 10:43:23 PST 2012
Hmmm....
I'm running 1.73 without problems on 12.1. I have libpython2.7 installed, from the main OpenSuse repository. QGIS seems happy with this, although I have not tried to upgrade to 1.74 yet.
Have you tried seaching for libpython with the Yast software manager & seeing what is available for your system?
Or you can use the OpenSuse one-click installer at:
http://software.opensuse.org/ymp/openSUSE:12.1:Update/standard/libpython2_7-1_0.ymp?base=openSUSE%3A12.1&query=libpython
HTH,
  Brent Wood
--- On Tue, 2/28/12, Donovan Cameron <sault.don at gmail.com> wrote:
Subject: Re: [Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
To: qgis-user at lists.osgeo.org
Date: Tuesday, February 28, 2012, 5:24 AM
I noticed my error when QGIS upgraded to 1.7.3 as well, but never got around to reporting it, then 1.7.4 came out soon afterwards. It opened and ran fine in v 1.7.2
I will check my python version when I get home tonight and see if that could be it if not, I may rollback to 1.7.2.
I'll follow your forum thread for updates as well.
Donovan
On Mon, Feb 27, 2012 at 8:24 AM, Kerick Leite <kerick.quimica at gmail.com> wrote:
I had a problem with the installation of QGIS 1.7.3 in the same version of OpenSUSE as yours. The problem was caused by a missing dependency also related to python. I've posted the problem in the forum, but so far there wasn't a reply:
http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6
Regards,
Kerick
Message: 6
Date: Sun, 26 Feb 2012 16:38:10 -0700
Subject: [Qgis-user] QGIS 1.7.4 doesn't run in OpenSUSE 12.1
Message-ID:
        <CAJo0jfPr+K5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
When I try to run qgis from the terminal, the splash shows, but as soon as
it gets to the part "Starting Python" the splash simply closes.
The output from the terminal is:
*qgis: siplib.c:10938: sipEnumType_alloc: Assertion
`(((currentType)->td_flags & 0x0007) == 0x0003)' failed.*
*Aborted*
I downloaded and installed QGIS from the "geo" repository (
http://download.opensuse.org/repositories/Application:/Geo/openSUSE_12.1/)
QGIS: 1.7.4-Wroclaw
OS: OpenSUSE 12.1 with KDE 4.8
Kernel: 3.1.9-1.4-desktop
Regards,
Donovan
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120226/8bedc4f5/attachment-0001.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120227/2be17074/attachment.html>
